Hi, the gyro module I have isn’t found by the gyro library (even the exampel program) when using the MegaPi but it is found when using the Orion. My question is if their is a way to define what pin/port you want to use or if it’s a bug.
Ultimate 2.0 with Gyro
tech_support
Hi NotSoWeird,
Using the Me 3-Axis Accelerometer and Gyro Sensor with MegaPi, you need use a MegaPi Shield for RJ25.
Then you can program it using Program block below on mBlock software:
If you want to program with Arduino software, you can modify the program according to example program for Gyro and Orion. Please read the README file under Makeblock library file to modify the program.
