Hi All.
Someone knows how to get documentation about programming of mbuild smart camera?
Every links (over the box and in internet) about it don’t works, returns error.
I’m trying to understand the commands about “motor differential speed” and - generally - the most efficienty and cool way to move mbot2 by this camera.
Please @tech_support .
[SOLVED] Documentation for Smart Camera Add-On Pack is not working
mBot2 Smart Camera
Hi @aieropoli! You can try putting the broken links into this to see if the pages have been archived (then you can view the archives):
Otherwise, if you have some specific questions (where to find the blocks, what do they do, etc.) I might be able to help you.
Thanks for the tip, but the page “https://docs.makeblock.com/halocode/en/mbuild/hardware/sensors/smart-camera.html” was also not archived there.
However, I doubt I would have found anything useful in it.
As I wrote, I’m trying to learn the most effective way to move mbot2 using the smart camera. I saw that the extension dedicated to the device has some commands related to movement, such as “motor differential speed”, and I wanted to find out more.
However, I find it scandalous that it is not possible to easily find documentation on these devices online (sold without even paper documentation).
Let me know what specific blocks you need help with if that doesn’t work. I don’t have the smart camera, but I can try to search for info about it…
Actually I found the solution thanks to your suggestion: everything was explained in the help😄. Thank you so much!
