Serial Communication Between Me Auriga and Arduino Nano
Hello, I am trying to connect my Me Auriga board to a Arduino Nano using port 5, I have connected them as follows:
MeAuriga | Nano
GND | GND
TX2 | RX0
RX2 | TX1
The Me Auriga is the receiver and the code is here:
char mystr[10]; //Initialized variable to store recieved data
void setup() {
  // Begin the Serial at 9600 Baud
  Serial.begin(9600);
void loop() {
  Serial.readBytes(mystr,5); //Read the serial data and store in var
  Serial.println(mystr); //Print data on Serial Monitor
  delay(1000);
And the code for the Nano, which is the sender:
   char mystr[5] = "Hello"; //String data
    void setup() {
      Serial.begin(9600);
    void loop() {
      Serial.write(mystr,5); //Write the serial data
      delay(1000);
What Happens:
When I connect them together on the nano, i just get prints of Hello on the serial monitor and it doesn’t matter if the port 5 cable is connected it just keeps printing hello.
While the Me Auriga serial monitor is blank.
What I Have Tried:
I saw this forum, which explains to use serial2, so I try to use serial2 for the Me Auriga but I still get the same output as before.
Any help would be greatly appreciated.
Try using Serial2 on the MeAuriga to receive and Serial to print to your PC. They’re different ports.
https://www.arduino.cc/reference/en/language/functions/communication/serial/
I’m only guessing, but here’s where I’d start:
void setup() {
Serial.begin(9600);
Serial2.begin(9600);
void loop() {
Serial2.readBytes(mystr,5); //Read the serial data and store in var
delay(1000);
It’s such a shame that the coding/API documentation for the Ranger is so very very non-existent.
Thank you so much it worked!! Yeah I was searching for any documentation but their was nothing, but thank you for fixing my problem
You’re welcome :slightly_smiling_face: glad to have helped. I’m new to MakeBlock products but have started by creating my own API documentation.
https://docs.google.com/document/d/1EpMWJo9pP2J_pstzXA-XHK8t00Z70SCZYwZ_Kl7VLuw/edit?usp=sharing feel free to share it.
