Robot Gripper
My Robot Gripper will not work and just makes a buzzing noise when unclamp and clamp button on control panel on my phone is pressed. I have switched the robot arm and gripper wires around to see if wires were the issue, but that was not the case. Any suggestions?
Same problem here with the small acrylic gripper. It seems that the resistance from the gripper mechanic keeps the servo motor its desired position.
I fixed it by loosening the screw on the top a bit.
Maybe I will also try to use some oil on the gear.
