Raspberry pi + python ultra sonic sensor
I’m trying to control the Ultimate 2.0 robot via Raspberry Pi and Python. At first I tested the ports 1-4 with the encoder motor everything worked fine.
megapi import *
def onRead(v):
print(“distance:”+str(v)+" cm");
if name == ‘main’:
bot = MegaPi()
bot.start()
while 1:
sleep(0.1);
bot.ultrasonicSensorRead(8,onRead);
Now after running the example code for the ultrasonic sensor. I can hear the sensor working for some time. Then it stops and the following message appears:
“device reports readiness to read but returned no data (device disconnected or multiple access on port?)”
Hi, may be you can take a look at this link: https://www.raspberrypi.org/forums/viewtopic.php?t=228315.
By the way, this is kind of DIY program which belong to advanced personal applicatin and beyong our support ability.
This code works for me with ultimate 2 and RPI
from megapi import *
distance = 123
def onRead(v):
global distance
distance = v
bot = MegaPi()
bot.start(’/dev/ttyUSB0’)
sleep(2)
print (“start test”)
while 1:
sleep(2)
bot.ultrasonicSensorRead(6,onRead)
print (distance)
idist = int(distance)
if idist < 12:
    print("time to turn")
Thank you, for your replies. I had to manually change the settings for UART in /boot/cmdline.txt.
you mean to remove the console entry (like console=serial0,115200).
Enjoy your new capabilities.
