My son and I are interested to know how we can connect a Raspberry Pi 4 to the MegaPi of the Ultimate 2.0 kit?
Is it compatible and what do we need to do this?
Thanks in advance.
#raspberrypi #megapi
Thanks in advance.
THe easiest way for the two boards to communicate is thru the USB port.
On the PI, run the lsusb command. (or ls /dev/tty*)
Connect the megapi to the PI wth a usb cable
On the PI, run the lsusb command.(or ls /dev/tty*)
THe new entry will be the port you communicate on.
I have used this method with multiple PI boards and Makeblock boards.
Great Thanks…
But can I also do it with the pins and plug it in so that it sits nicely onto of each other as it was with the RaspberryPi 3 in the examples? Would the RaspberryPi 4 connecting be exactly the same as the RaspberryPi 3?
Thanks, Andrew
The physical specs(distance between the holes: 49 x 58) on the RPI 3 vs 4 seem to be the same and the 5x2 GPIO ports are the same.
The RPI 4 runs much hotter and I would be concerned with the megapi sitting on top without much higher pins. I suppose you could have both boards vertical vs horizontal.
