I would like to know if Ultmate 2.0 kit is supposed to be programmed only using Makeblock App for portables or it can also be done using mBlock 5 on PC.
Im trying to program Ultimate 2.0 on PC connected via USB. On mBlock 5 i try to add device im coding but there is no Ultimate 2.0.
Any information would be helpful, thank you
Programming software for Ultimate 2.0
Brightwood
The Ultimate 2.0 kit uses the MegaPi board, if memory serves so I would say to look for that board. To be honest, I’m not sure that it will be supported in mBlock 5. @tech_support, can you provide any information?
tech_support
Hi Brightwood and Chuck,
I am afraid Ultimate 2.0 won’t be added to mBlock 5, at least there is no plan yet.
For PC software, you can use mBlock 3 (latest 3.4.11)
Hi @tech_support,
That’s what I thought I remembered reading a few weeks ago. @Brightwood, I’d suggest spending some time with the Arduino programming environment. It’s pretty straightforward after you do a few sketches.
Regards,
Chuck
system
