I have just built the Robotic Arm controlled by the Android app.
Everything works fine except the 25mm motors, which have no output signal (measured in the port).
The motors are OK, provided I have tested both out of the circuit.
Unsuccesfully, I have upgraded the firmware, using the link https://github.com/Makeblock-official/Makeblock-Firmware/tree/master/mblock_firmware (version 1.10101 del 03/06/2014) which gives me compilation warnings under Arduino 1.6.6:
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of '191' from 'int' to 'int8_t {aka signed char}' inside { } [-Wnarrowing]
0xb9,0xde,0xf9,0xf1,0x40};//0~9,A,b,C,d,E,F,-
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘134’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘219’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘207’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘230’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘237’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘253’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘135’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘255’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘239’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘247’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘252’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘185’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘222’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘249’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\Me7SegmentDisplay.cpp:9:32: warning: narrowing conversion of ‘241’ from ‘int’ to ‘int8_t {aka signed char}’ inside { } [-Wnarrowing]
sketch\MePort.cpp:44:7: warning: extra tokens at end of #else directive [enabled by default]
#else if defined(AVR_ATmega328) // else ATmega328
sketch\MePort.cpp:72:7: warning: extra tokens at end of #else directive [enabled by default]
sketch\MePort.cpp:11:1: warning: narrowing conversion of ‘-1’ from ‘int’ to ‘uint8_t {aka unsigned char}’ inside { } [-Wnarrowing]
El Sketch usa 23.972 bytes (74%) del espacio de almacenamiento de programa. El máximo es 32.256 bytes.
Las variables Globales usan 1.198 bytes (58%) de la memoria dinámica, dejando 850 bytes para las variables locales. El máximo es 2.048 bytes.
In there any solution reported?
