ok, thank you all.
im the past i had the mbots connected usb to windows systems, coded the remote control, and used the infrared remote control that came with the mbot… all great.
this new mbot2, i have no idea, do we code the mbot2 then upload to the mbot2 then remove the cyberpi to control it wit hthe cyberpi joystick? i also have a makeblock remote controoller device too, but i dont know how to use it,=.
when i looked at the tutorials it showed how to code it, BUT i dont know where to code it all, do i do it under the cyber pi device, the mbots2 the remote controller, every time i click on 1 it clears the code i already put in place, as well some of the sample blocks arent even there unless im clicked on the remote controller device…
i see the sample programs in mblock5, but im still unclear how to start a simple remote control from nothing (not using the example programs)
are there any good tutorial videos, does the mbot2 need a wifi network to work, as im in a classroom and we cannot just ‘connect’ to the school wifi (im thinkinig of getting a little travel router and connecting that for the mbots to use and communicate?)
can y’all point me in the right direction, i was so good with the older mbots
mm
