mBot upload issues on Chromebook, timeout and upload fail
hi experts, thank you,
so my classroom has all new chrome desktops, and i connected an mbot v1 via usb to the chromedesktop, it connected using /dev/ttyusb0 port (?), but it said ‘connected’ i went to a sample program for the mbot, tried yto upload to mbot, received the following error.
mcore_upload_fail_fded06b5
mcore_upload_fail_17773a37
error: sending 3020: receive data timeout after 1000ms
here si the link to a screenshot:
``https://www.dropbox.com/scl/fi/lwuv70z5e4tvjxkw8yxib/20231218_131442.jpg?rlkey=rtufkl7i98ekty7wwkac70ohx&dl=0
It means you connected to the wrong port or the mBot needs to be restarted. @magicmarc check out the conversation here to see if it helps:
Are there any other ports available for connection?
thank you @best_codes ! the restart and making sure mlink is running seemed to work!
mm
Awesome! If you have any more issues, be sure to mention me as @Best_codes.
