Hello, just bought a Ultimate robot kit for Radioshack. I have experience with Arduino Uno.
From the box I’ve been able to build the Robotic Arm Tank and worked fine, just the RGB strip didn’t work. The next day I decided to program the Orion board with the Macbook and problems started to arise. Couldn’t use the Arduino IDE neither following the directions of the Makeblock webpage. Tried to upload the CH34 and the using terminal but nothing happened. Anyhow I could make Arduino IDE to show Ardublock but no Makeblock orion card. Then I tried Scratchbot showing connected via bluethoot showed connected but nothing worked so I tried connecting it via USB, same story there. I tried then upgrading firmware and after several times it worked, after that the card stopped responding at all. So I tried again with bluetooth and the app on the iphone which told me to download the firmware, it started and freezed at about 30%. Now it says the same that needs the firmware and asks to reset arduino but when I hit the button nothing happens, its unresponsive. I tried to upload a sketch with Arduino IDE using USB and selecting Arduino UNO card but shows this error: " This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Mac OS X), Board: “Arduino Uno"
Tamaño binario del Sketch: 1.082 bytes (de un máximo de 32.256 bytes)
avrdude: stk500_recv(): programmer is not responding”
Please help. Thank you.
