Good morning!
I am trying to operate the MakeBlock Ultimate 2.0 with the MakeBlock Bluetooth Controller. It seams the pairing is ok:
1- Both blue LED’s from the controller and robot flashes
2- Then, holding the pairing button in the controller it flashes rapidly, becoming both LED’s fixed after a few seconds.
However, the robot doesn’t respond to any order from the controller!
When I try with the App on my mobile device, everything works fine!
Can you help me with some suggestions to check what is the problem?
I could try several options if I had time. Unfortunately I am almost over a deadline to present a project so I need some shortcuts to get a solution faster.
Thank you very much for your help.
Duarte
MakeBlock Bluetooth Controller issues
dcota
Bleky
Download and unzip this file,there should be an example program for Ultimate. Upload that and you should be able to drive the robot around using the controller.
system
