I’ve tried using Svg, dxf, and png and I get weird errors from all of them. Randomly.placed lines that cut through the middle of the image or the y axis failed to move and the cutter just bounces back and forth cutting in a straight line. Are there any other softwares that are compatible with the megapi. MLaser is just a mess. Otherwise I’m going to have to scrap the megapi and replace it with my own configuration so I can use repetier. Which I really don’t want to do.
Laserbot megapi laser software errors
Hi spackman,
What is the error when import the images to mLaser?
Could you please attach the images here.
As of the abnormal working with the laserbot, please kindly check if the Laserbot works ok by testing the Home.
You may refer to this instruction to test Home on Laserbot.How to test if the wires connection for X, Y axis connected properly on Laserbot.zip (321.9 KB)
Besides, may I know what is the operating system of your PC and which version mLaser do you use?
Please make sure that you have installed the latest version 2.3 mLaser software.
Let me explain this more clearly…
The wiring is correct.
The laser responds to G code commands.
My problem is the fact that mLaser freaks out and turns rectangles in to triangles and does weird interpretations of my drawings. Also the software doesnt allow multiple drawings. I would like to program more passes for specific lines and less for others. Lets say i want to engrave something and also cut it out… mLaser is the problem. I don’t need troubleshooting tips. I need alternate software that works.
Hi spackman,
There is no external software Except mLaser for Laserbot.
Since mLaser is open sourced software, if you are geeks, you may modify it to achieve the function you want.
The best alternative is to get an arduino mega with a ramps board. There are alot of diy laser cutters out there. The typical laser software operates more like cnc. You can select lines and choose power and number of passes. You can also engrave and cut on the same drawing. As to laserbot i really bought it for the frame. I upgraded the laser to a 3.8 watt laser! It is amazing. I can cut through black acrylic in one pass at 400mm/min. You can look around. here is a place you might find some answers. http://3dpburner.blogspot.com/ Luckily the board is the cheapest part of most machines. Its really the hardware and the motors. A a decent stepper motor is about as expensive as an arduino.
