How to connect Ms-12A smart servo with Megapi?
As far as I know,only Auriga,MegaPi Pro and NovaPi have the port for connecting MS-12A smart servos.
I googled and found different pictures of Megapi but this shows a smart servo interface https://www.makeblock.com/project/megapi-pro
Yeah,that’s the Pro version. Normal version doesn’t have it.
If using the other megapi board then you can still make a smart servo (serial bus servo) by using the serial and a power source see the marked pins below you will need to just make up the cable.
Yes,
There is not a preset connector for smart servo on Megapi.
Megapi pro and Me Auriga is compatible with smart servo.
If you want to connect the smart servo to Megapi, you can try the method outoftheBOTS mentioned.
Thanks.
