Thank you from tech support for the suggestions:)
I am still trying however to get a motor to work. We have a class of students waiting to use the robots!! PLEASE CONTINUE TO HELP
Again here is a link to the micro controller and motor
Here is the code I am using:
#include <MeMegaPi.h>
MeEncoderOnBoard Encoder_1(SLOT4);
MeEncoderOnBoard Encoder_2(SLOT2);
void isr_process_encoder1(void)
if(digitalRead(Encoder_1.getPortB()) == 0)
Encoder_1.pulsePosMinus();
else
Encoder_1.pulsePosPlus();;
void isr_process_encoder2(void)
if(digitalRead(Encoder_2.getPortB()) == 0)
Encoder_2.pulsePosMinus();
else
Encoder_2.pulsePosPlus();
void setup()
attachInterrupt(Encoder_1.getIntNum(), isr_process_encoder1, RISING);
attachInterrupt(Encoder_2.getIntNum(), isr_process_encoder2, RISING);
Serial.begin(115200);
//Set PWM 8KHz
TCCR1A = _BV(WGM10);
TCCR1B = _BV(CS11) | _BV(WGM12);
TCCR2A = _BV(WGM21) | _BV(WGM20);
TCCR2B = _BV(CS21);
Encoder_1.setPulse(7);
Encoder_2.setPulse(7);
Encoder_1.setRatio(26.9);
Encoder_2.setRatio(26.9);
Encoder_1.setPosPid(1.8,0,1.2);
Encoder_2.setPosPid(1.8,0,1.2);
Encoder_1.setSpeedPid(0.18,0,0);
Encoder_2.setSpeedPid(0.18,0,0);
void loop()
if(Serial.available())
char a = Serial.read();
switch(a)
case ‘0’:
Encoder_1.moveTo(0,300);
Encoder_2.moveTo(0,300);
break;
case ‘1’:
Encoder_1.moveTo(360,300);
Encoder_2.moveTo(-360,300);
break;
case ‘2’:
Encoder_1.moveTo(1800,300);
Encoder_2.moveTo(-1800,300);
break;
case ‘3’:
Encoder_1.moveTo(3600,50);
Encoder_2.moveTo(-3600,300);
break;
case ‘4’:
Encoder_1.moveTo(-360,50);
Encoder_2.moveTo(360);
break;
case ‘5’:
Encoder_1.moveTo(-1800,50);
Encoder_2.moveTo(1800,50);
break;
case ‘6’:
Encoder_1.moveTo(-3600,50);
Encoder_2.moveTo(3600,50);
break;
default:
break;
Encoder_1.loop();
Encoder_2.loop();
Serial.print(“Spped 1:”);
Serial.print(Encoder_1.getCurrentSpeed());
Serial.print(" ,Spped 2:");
Serial.print(" ,CurPos 1:");
Serial.print(Encoder_1.getCurPos());
Serial.print(" ,CurPos 2:");
Serial.println(Encoder_2.getCurPos());
HERE ARE THE WARNING MESSAGES WE ARE RECEIVING:
In file included from C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeMegaPi.h:65:0,
from C:\Program Files (x86)\Arduino\libraries\makeblock\examples\Me_On_Board_encoder\Me_Megapi_encoder_pid_pos\Me_Megapi_encoder_pid_pos.ino:32:
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:73:0: warning: “SLOT_1” redefined
#define SLOT_1 1
In file included from C:\Program Files (x86)\Arduino\libraries\makeblock\src/Me7SegmentDisplay.h:70:0,
from C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeMegaPi.h:42,
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:108:0: note: this is the location of the previous definition
#define SLOT_1 SLOT1
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:74:0: warning: “SLOT_2” redefined
#define SLOT_2 2
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:109:0: note: this is the location of the previous definition
#define SLOT_2 SLOT2
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:75:0: warning: “SLOT_3” redefined
#define SLOT_3 3
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:110:0: note: this is the location of the previous definition
#define SLOT_3 SLOT3
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:76:0: warning: “SLOT_4” redefined
#define SLOT_4 4
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:111:0: note: this is the location of the previous definition
#define SLOT_4 SLOT4
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:77:0: warning: “SLOT1” redefined
#define SLOT1 SLOT_1
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:104:0: note: this is the location of the previous definition
#define SLOT1 (1)
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:78:0: warning: “SLOT2” redefined
#define SLOT2 SLOT_2
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:105:0: note: this is the location of the previous definition
#define SLOT2 (2)
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:79:0: warning: “SLOT3” redefined
#define SLOT3 SLOT_3
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:106:0: note: this is the location of the previous definition
#define SLOT3 (3)
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MeStepperOnBoard.h:80:0: warning: “SLOT4” redefined
#define SLOT4 SLOT_4
C:\Program Files (x86)\Arduino\libraries\makeblock\src/MePort.h:107:0: note: this is the location of the previous definition
#define SLOT4 (4)
Sketch uses 11,964 bytes (4%) of program storage space. Maximum is 253,952 bytes.
Global variables use 1,420 bytes (17%) of dynamic memory, leaving 6,772 bytes for local variables. Maximum is 8,192 bytes.
