Hi all. Just received the ultimate kit 2.0 for christmas. I can connect to it and control it via the app on my phone, however when I try to connect using my laptop half the time mBlock won’t even show it when I try to discover the connection and the other half the time, when I can discover it and try to connect it just times out. Laptop is a Windows 10 Asus T100TA. Thanks in advance!
-Wuss
Bluetooth connection problems with PC
wussie
tech_support
Hi wussie,
which version mBlock do you use? Please make sure you are using the latest version 3.4.4
Besides, you may change the battery have a try since the Bluetooth may not work properly when there is no enough power. According to our test and research, it is suggested to use rechargeable Li-ion battery or rechargeable nickel-metal hydride, nickel-cadmium which can be bought from amazon or local shop. Or Alkaline battery with good quality like Energizer, DURACELL.
tech_support
Hi Wussie,
Is there any problem when you connect this PC to Bluetooth signal from other device instead of the mBot.
If it is possible, please also check with another PC.
