Are my motors faulty?
I purchased an “ultimate robot kit” and have been experimenting with different projects. I noticed that my 25mm and 37mm motors won’t operate at anything under the value “100” (on the 0-255 scale). If I try to rotate them slowly at value “50” they just whine. This is while using the provided 6 AA battery holder and a fresh set of Duracells.
Are my motors faulty? Or is it a known limitation of the DC motors? I’m considering upgrading the motors but I’d like to find some that I don’t have to solder connectors to.
@Dave_Dillon,
Actually this is quite common. About the lowest value to get the motors to run consistently is 70 - 80 (besides selecting from the drop down, you can type in values). It has something to do with the PWM (Pulsed Wave Modulation) and the minimum current requirements for the motors.
Mike
