My plotter is only moving in the x direction.
Both of my stepper drivers have red led lights on. Both are set to HHH (I am using mdraw).
The motor that moves in the x direction is functioning.
The motor that moves in the y direction appears to be on (when I touch it there is slight movement), but it isn’t moving the timing belt or axis. It is just wiggling it back and forth (less than a mm in linear distance).
How can I fix this?
