I’ve built an xy plotter version 2.02 with the Orion board. It took a while but I figured out that I could print from GRemote using certain settings after getting the right firmware flashed to the board. The GRemote settings are:
XDir 11, YDir 3, ZDir blank, XPPM 174.9781
XStep 10, YStep 9, ZStep 15, YPPM 174.9781
XMin 17, YMin 13, ZMin blank, ZPPM 174.9781
XMax 16, YMax 12, ZMax blank
I’ve successfully printed all of the examples using these setting from both mac and windows machines.
Now I’m trying to print my own SVG files or other custom drawings. I’m not able to print from MDraw from either Mac or Windows. I load a file and hit play but nothing happens. Is it because only certain versions of MDraw are set up to work with the XY 2.02 Orion boards? What version of MDraw will work with this setup and where can I find the link? Thanks!
