The WiFi modules uses point-to-point WiFi and just seems (at least here) to “pair” up automatically. I had to wait a few seconds for the “pairing” to occur and only had the bot being paired actually powered up.
Soooooo…
Let’s try this procedure.
- Exit mBlock.
- Turn off the mBot.
- Make sure there are no other unpaired mBots turned on.
- Turn on the mBot.
- Run mBlock.
- Click on the Connect->Serial 2.4G menu item.
- Count to ten slowly.
- See if the title bar in mBlock says connected.
If it still is not “pairing up,” then try to reseat the WiFi module. I’m not sure which version of the mBot that you have. Version 1.0 has no plastic case over the mCore board while Version 1.1 has a protective case. If you have the 1.1 version, you’ll need to open the case try to reseat the WiFi module towards the back of the mCore board. It’s the only module that can be removed for what it’s worth.
The procedure I would recommend is to:
- Turn of the power of the mBot.
- Gently remove the WiFi module.
- Gently reseat the WiFi module.
- Power up the mBot and then see if this corrects the issue (don’t close the case back up until it works!)
That’s likely the best I can help without actually being there.
Regards,
Chuck
