Will a mix of hardware work?
I just ordered a bluetooth starter kit and some of goodies. Knowing the starter kit does not work with Mblock5, I also ordered an Auriga controller and a Me dual motor driver. Once I get everything together and substitute the Me Auriga for the Orion controller will I be able to call it a Ranger in Mblock5 and go? Thanks.
Yes the device you select in mblock5 will be dependent upon the control board your using. So if your using the Aruiga board then select the ranger if your using the Orion then select mbot
