WiFi (esp8266) robot
Hi!
Has anyone tried to connect a typical ESP8266 module in the bluetooth socket of makeblock? I suppose that properly supplying the ESP8266 module you can use the same Tx and Rx pins of bluetooth makeblock socket, right?
Regards
Javi
Sending MBot sensed values to host
Here is a link where shows the circuit schematic of Makeblock Me Wifi module. You may check if the info helps to your application.
Thanks, but I was wondering if it’s possible to connect a third-party ESP8266 (http://benlo.com/esp8266/ESP8266-ESP01.jpg) in the makeblock Bluetooth socket (not in sensor sockets), just manually wiring TX, RX, Vcc and GND connections of ESP8266.
(I edit: I’m using the basic mbot)
Thanks!
Javi
I saw online that the Bluetooth socket of mcore is directly connected to serial communication, so would it be possible doing a connection like this?
Thanks!
For this kind personal DIY application, we may don’t have enough ability to support.
Maybe some one who has similar project can share it.
BR
Finally I went ahead and tried to connect a third party ESP8266 directly to RX/TX pins in the board…
Now I have an IoT controlled robot :robot:!
I have similar project to work with… have you been able to send command from esp8266 to mcore and vice versa?
Yes, the RX/TX pins are directly connected to mcore, so you can connect a serial device and communicate them.
In mcore you must use: SoftwareSerial mySerial(0, 1); // RX, TX
You must disconnect serial devices when uploading code!
https://forum.arduino.cc/index.php?topic=412164.0
Javi
Javi, did you you the wiring as in the diagram above?
Yes, in my case I used a Wemos D1 mini. So I just connected:
Wemos Rx --> mcore Tx
Wemos Tx --> mcore Rx
Wemos 5V --> mcore 5V
Wemos GND --> mcore GND
Thank you… i will try it hopefully it works
I tried to code the program using arduino ide but mcore doesn’t accept programs from arduino ide, I have to program it from mblock but there’s limitation I can’t include some functions such as SoftwareSerial x(0,1) …, how did you upload it??
What version of Arduino IDE are you using? mcore is detected as Arduino UNO, so you select corresponding usb port and upload code
#14
i’m using 1.6.12 but there’s no option for arduino uno board
#15
I have both Arduino IDE 1.6 and 1.8 and I have the option of Arduino UNO, check in tools, boards
#16
can you share your sample sb2 or ino file?
#17
