I have a lenovo yoga, two weeks ago in my robotics class, i could not send the info to legting my group with a bad mark, the next two weeks the same happened. How can i fixit?
PD: I already restarted the laptop, reinsall mblock
When trying to upload to arduino, it disconects and nothing happens
Please try to record the issue and send a video to my email box stephanie.wu@makeblock.com.
Also what is the main board you used?
What is the codes you tried?
Her same problem. 1 of 20 times it works, strange, because for months everything worked fine and suddenly ther is a problem uploading the code using the chromebook app, on my Mac device it works fine.
A video: https://youtu.be/jGxeuXc3p7g
Hi henkvdh,
This server should not be stable and this software is not under maintenance, please try mBlock 5/mLink.
mBlock 5 is the main software and we will focus on mBlock 5, for other version like mBlock 3 on chromebook, we won’t do any update. The issue like failing to upload or compile in that version, I am afraid the fix is set in a very low priority. In order not to influence your application, we suggest mBlock 5.
Yes. Programs created with mblock3 can be opened with mblock5. (Since you understand your text with automatic translation, it may have a wrong meaning.)
No, a program Made in MBlock 3 I can not open in MBlock 5 there are Some programblocks that dont exist anymore
I’m sorry, it was still wrong.
By the way, can you give me an example of a non-existent block?
mBlock 3’s program is .sb2, while mBlock 5’s is .mblock.
What are those non exist blocks in mBlock 5? We’ll check if we will add later.
