What's the input voltage and current consumption of CVCO55CC-3619-3711?
Crystek’s CVCO55CC-3619-3711 VCO (Voltage Controlled Oscillator) operates from 3619 MHz to 3711 MHz with a control voltage range of 0.1V~16V.
This VCO features a typical phase noise of -106 dBc/Hz @ 10KHz offset and has excellent linearity. Output power is typically +5.0 dBm. The model is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package.It is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Do you know the input voltage and current consumption of CVCO55CC-3619-3711 ?
Waiting for your reply.
