Do you know, what type of light sensor is integrated in the mCore board? I can’t find the information nowhere, does it use a photo diode or a light dependent sensor?
Thank you!
Thank you!
It’s a typical photosensor. Here’s a link to that on Adafruit. I found a great breakdown of the mCore board here.
The light sensors are pretty much the same, especially with regard to Arduino code. It would be helpful if @tech_support could provide a data sheet, but the blog article calls it out as a pretty standard sensor. I just looked through the source code in the official Makeblock Arduino libraries (link) and essentially you get methods to do analog reads/writes and the ability to turn on an LED if it is present.
I am afraid there is no English version data sheet. I sent you some parameters of our light sensor on mCore.
Thank you so much!
Is there any place where I can see the sensitivity and the frequency response of that sensor?
