Use arduino c for programming
Hi!
I want to use Arduino c for programming my mbot.
I have installed the lastest Arduino from https://www.arduino.cc/en/main/software and have donwload the libraries from https://github.com/Makeblock-official/Makeblock-Libraries and have add the libraries over Sketch-> Include Library-> Add .ZIP Library.
I have select the board Arduino uno and the port.
When I press the upload button I will get the following message:
Der Sketch verwendet 4014 Bytes (12%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 688 Bytes (33%) des dynamischen Speichers, 1360 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x5c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x5c http://www.arduino.cc/en/Guide/Troubleshooting#upload
I use the following Code:
#include <MeMCore.h>
MeRGBLed led;
void setup() {
// put your setup code here, to run once:
led.setpin(13);
void loop() {
// put your main code here, to run repeatedly:
led.setColorAt(0,0,0,255);
led.show();
delay(500);
On an other Computer all is fine. the only different I notice is that I have no Board Arduino/Genuino Uno. I can only choose Arduino Uno. Maybe this is the Problem but I don’t know how I can install the Board Arduino/Genuino Uno.
Hope somebody can help me.
kindly regards
Try going into the boards manager and making sure you have all the updates for Arduino AVR boards (current version 1.8.2).
(Adrduino -> Tools -> Board -> Boards manager)
Also check the serial port driver is the same one you’re using on the other PC (same cable too?)
