Uploaded problem
I unfortunately have to go through version 3 of mblock
Because I am a technology professor and the college where I am does not have version 5 of mblock
This is not a problem in itself since I download version 3 but the problem is that I can’t teletransvers the program
into mbot .
A smal windows appear and it mentionned “UPLOADED 0%” and few minutes later this same window show “uploaded failed” i didn’t know what is probleme i think is the compatibiliti with Windows 10 no ?
Thanks for your help i’m lost
Voici le code :
28
29
30
31
34
35
36
37
38
39
40
41
42
43
44
45
46
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <MeMCore.h>
MeDCMotor motor_9(9);
MeDCMotor motor_10(10);
void move(int direction, int speed)
int leftSpeed = 0;
int rightSpeed = 0;
if(direction == 1){
leftSpeed = speed;
rightSpeed = speed;
}else if(direction == 2){
leftSpeed = -speed;
rightSpeed = -speed;
}else if(direction == 3){
leftSpeed = -speed;
rightSpeed = speed;
}else if(direction == 4){
leftSpeed = speed;
motor_9.run((9)==M1?-(leftSpeed):(leftSpeed));
motor_10.run((10)==M1?-(rightSpeed):(rightSpeed));
double angle_rad = PI/180.0;
double angle_deg = 180.0/PI;
void setup(){
move(1,50);
void loop(){
_loop();
void _delay(float seconds){
void _loop(){
here it’ sems too consol
is not responding
avrdude.exe: stk500_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcf
avrdude.exe: Send: 0 [30] [20]
avrdude.exe: ser_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcf
avrdude.exe: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcf
avrdude.exe: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcf
avrdude.exe: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcf
avrdude.exe: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcf
avrdude.exe: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcf
avrdude.exe done. Thank you.
Hi, do you use mBlock3 web verion or mBlock software? What the program did you try to upload? Connected via USB Cable or Bluetooth?
