Upload issues
When uploading from a student profile (full access to install DIR at c:\mblocks2) i receive the following error,
C:\Program Files (x86)\mBlock\Arduino\arduino_debug.exe --upload --board arduino:avr:uno --port COM6 --verbose --preserve-temp-files C:\Users\student\AppData\Roaming\com.makeblock.Scratch3.4.11\Local Store\scratchTemp\project_Untitled2_1\project_Untitled2_1.ino
Loading configuration…
org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:377)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:160)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:147)
at processing.app.windows.Platform.getFolderPathFromRegistry(Platform.java:70)
at processing.app.windows.Platform.recoverSettingsFolderPath(Platform.java:55)
at processing.app.windows.Platform.init(Platform.java:50)
at processing.app.Base.guardedMain(Base.java:153)
at processing.app.Base.main(Base.java:137)
When running the application as administrator and using my domain admin credentials i get success,
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
double angle_rad = PI/180.0;
double angle_deg = 180.0/PI;
void setup(){
void loop(){
_loop();
void _delay(float seconds){
void _loop(){
0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file “C:\Users\pilchs\AppData\Local\Temp\build1530209204563589666.tmp/project_Untitled3_2.cpp.hex”
avrdude: writing flash (1762 bytes):
Writing | ################################################## | 100% 0.30s
avrdude: 1762 bytes of flash written
avrdude: verifying flash memory against C:\Users\pilchs\AppData\Local\Temp\build1530209204563589666.tmp/project_Untitled3_2.cpp.hex:
avrdude: load data flash data from input file C:\Users\pilchs\AppData\Local\Temp\build1530209204563589666.tmp/project_Untitled3_2.cpp.hex:
avrdude: input file C:\Users\pilchs\AppData\Local\Temp\build1530209204563589666.tmp/project_Untitled3_2.cpp.hex contains 1762 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.18s
avrdude: verifying …
avrdude: 1762 bytes of flash verified
avrdude done. Thank you.
send encode mode
binary mode char mode
recv encode mode
Anybody had this issue? not sure if its a java issue or the software
Hi simonpilch,
Do you mean that you can only upload mBlock program with administrator right on the computer?
If yes, may I know which version mBlock and what is the operating system of your computer?
Hi Thanks for the reply,
Yes that is correct, seems I cannot get an upload unless i have administrative rights running the software,
Windows 7 pro
mBlock 3.4.11
Hi simon,
How about try install the mBlock software under the D disk instead of the C disk on the Computer?
There isn’t a D drive on the machine
Hi simon,
Do you mean the computer only has C disk?
If yes, you may try install the mBlock under the root directory of the C disk (like C:\mBlock) and see if it helps.
Hi If you check my initial post i have stated it is installed under c:\mBlocks2,
Hi simonpilch,
Sorry for that! In this case, I am afraid there is no other work around.
Currently,our engineers are developing the mBlock 5 which base on scratch3.0. The mBlock 5 doesn’t need administrator right to upload the program and will support all of the Makeblock robots gradually. You may use the mBlock 5 when it support the robot you use.
Hi simonpilch,
We have some progress on this problem, please try install the mBlock software under the Program data file in C disk (C:\ProgramData) have a try.
