Upload faild (2.4Gversion mbot)
This is running on window7 @ Samsung notebook. And I have finished the step below via USB cable.
  1. Arduino driver has installed.
  2. Connection successfully completed.
  3. Firmware has upgraded.
  4. Test program has even executed successfully by double click the 'Mbot program" hat.
I removed all of arduino reltaed files and folder except mblock folder with several rebooting.
However, uploading has not worked at all!
Even the same code worked very well in my desktop using window 7. I think it is coming from setting issue. Please
Please see the log file what I have been notified below.
initializing packages…
Preparing boards…
Verifying and uploading…
弃歹:C:\Program Files\mBlock\Arduino\hardware\arduino\avr\libraries\Wire 狼 扼捞宏矾府 Wire 荤侩
弃歹:C:\Program Files\mBlock\Arduino\hardware\arduino\avr\libraries\SoftwareSerial 狼 扼捞宏矾府 SoftwareSerial 荤侩
弃歹:C:\Program Files\mBlock\Arduino\libraries\makeblock 狼 扼捞宏矾府 MakeBlockDrive 荤侩
**{runtime.tools.avr-gcc.path}/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\mBlock\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\mBlock\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files\mBlock\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files\mBlock\Arduino\hardware\arduino\avr\libraries\SoftwareSerial -IC:\Program Files\mBlock\Arduino\libraries\makeblock\src C:\Users\Jinwoo\AppData\Local\Temp\build7373408038383556839.tmp\project______c_8_1.cpp -o C:\Users\Jinwoo\AppData\Local\Temp\build7373408038383556839.tmp\project______c_8_1.cpp.o **
Cannot run program “{runtime.tools.avr-gcc.path}\bin\avr-g++” (in directory “.”): CreateProcess error=2, 瘤沥等 颇老阑 茫阑 荐 绝嚼聪促
12:42:48.688 < 56 65 72 73 69 6f 6e 3a 20 30 36 2e 30 31 2e 31 30 36 0d 0a
I`ve fixed this issue by myself. It can be resolved by remove the reference.txt file in AppData/roaming/ folder and re-install mblock. I remind this post for your information.
