Upload Fail Error 1
Hi everyone,
I am trying to upload the follwoing to my mcore robot
The problem is I am getting the fowllowing error:
Loading configuration…
org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:377)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:160)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:147)
at processing.app.windows.Platform.getFolderPathFromRegistry(Platform.java:70)
at processing.app.windows.Platform.recoverSettingsFolderPath(Platform.java:55)
at processing.app.windows.Platform.init(Platform.java:50)
at processing.app.Base.guardedMain(Base.java:153)
at processing.app.Base.main(Base.java:137)
I am using USB, the driver is installed properly, My process for starting uploading to the robot is I plug into the computer via USB, turn on robot, select the proper serial port, reset default program, upgrade firmare, select upload to arduino. And then I get the error.
Any ideas?
What version of mBlock are you using?
What operating system are you using?
Hi Jho,
Please make sure you have chosen correct serial port.
Besides, please remove the Bluetooth /2.4G wireless module from mCore while you upload the program.
Once still the issue, please let us know more info as Chareles asked?
If it is possible, you may take a video to show your operation, which can be help to locate the problem.
