The BT dongle appears in Windows as USB-Serial CH340 (COM7) . However when trying to connect, nothing happens.
Unable to connect to mBot using BT dongle
Best_codes
@dhroller Are you following these steps?
- Turn on the mBot.
- Plug the makeblock Bluetooth Dongle into a USB port on your device.
- In mBlock 5, connect to the USB port you plugged the dongle into.
- Place the mBot near the dongle.
- Push the Bluetooth icon (button) on the dongle. The light will flash quickly for a while. If the light returns to flashing slowly, no device was found; if it turns solid and does not flash, the connection was successful.
After doing all that, create a code, go to ‘Upload Mode’, and upload the code to your device by clicking the ‘Upload Code’ button. Let me know if that helps you.
CommandeR
@dhroller Make sure that you have no other USB device (printer etc.) turned on at the same time - the dongle doesn’t like competition !
Best_codes
@dhroller what @CommandeR said is definitely true. I have experienced that before. Usually, the mBot will flash and / or play a sound when connected to the dongle to let you know you are connected to it.
system
