I am trying to connect mBot to windows10 computer to run a program.
The mBlock software version is v3.4.5 and I tried the following steps:
Connect -> Serial Port -> COM 3 (mbot dot turns green)
Now, if I try upgrade firware, the upload fails.
If I try running the program, it gives the following error:
System wide configuration file is “C:\Program Files (x86)\mBlock\Arduino\hardware\tools\avr\etc\avrdude.conf”Using Port : COM3 Using Programmer : arduino Overriding Baud Rate : 115200
avrdude.exe: Send: 0 [30] [20]
avrdude.exe: ser_recv(): programmer is not responding
avrdude.exe: stk500_recv(): programmer is not responding
avrdude.exe done. Thank you.
Can someone please help with what how to connect the mblock to mbot and run the program. I have the MBot Educational Robot Kit with Bluetooth version.
