Ultrasonicsensor dont Works
Hey,
I have my Robot a feew days ago but the ultrasonicsensor dont works It show me only 0 can someone help me please?
seems I have the same problem. When delivered, the sensor did it’s job, but now inside mblock the ultrasonic sensor seems to return 0 all the time
Could you upload your program? If you connect ultrasonicsensor with wrong port, it will show 0. So, double check your wiring. Hope it helps.
Thanks But i checked all the port, the power LED but their is nothing wrong
Here is the programm
@pasch It seems you use Orion board. So select Board> Me Orion, Extensions> Makeblock, Connect> Serial Port(choose the port of usb). Did you upgrade firmware to Orion board?
I got exactly same result as you before upgrading firmware. But when I did it, problem was solved.
it works!!! thank you very very much
