Touch Sensor
Why is my ME Touch Sensor not working after running this codes?
touch%20sensor%20code
Hi, do you have try to update the firmwre before you running this codes? I did run this codes, it works well.
yes. i have updated the firmware before i run the codes
the color of the LEDs does not change as a touched and not-touched the sensor. It stays in red color leds. The condition of the if block is always false.
When I tried this programe, it color changed, but it was a little slowly… If the touch sensor is sitll not working, you are suggested to contact your seller for a replacement when you are in warranty.
