Three questions about "bring sketch to life" function
Hi.
I have two questions about the “Bring sketch to life” feature of laserbox.
  1. Is there image data of the round code in the lower right corner of the makeblock official material?
  2. Can the “Bring sketch to life” function be used even when using a personal computer?
    Thanks
Hi dai5_jp,
1)Sorry we can’t provide the image date of the round code.
2)“Bring sketch to life” function can be used without connected to the software as long as you have checked this feature.
By the way, Laserbox software needs 64-bit Windows 7 or macOS Mojave10.13
https://www.makeblock.com/laserbox-2/#Software
Thanks.
I have one more question.
When offline, laserbox cuts red lines and engraves black lines with the “sketch cut pro” function. Can this function be used even when the laserbox is connected to a computer?
The reason I asked this question was that I wanted to process patterns drawn on non-official materials.
Hi dai5_jp,
If you mean the bring sketch to life pro, it will work when you drawn on a white paper.
The only difference is, it will at bring sketch to life as default.
You need to change to pro from the software if you want to use the pro function.
Hope I have explained it clearly.
Thanks.
