Third-party library
I want to include “src/HX711.h” into mblock 5.
I followed this documentation, but I couldn’t succeed.
this => https://www.mblock.cc/doc/en/developer-documentation/tutorials/create-arduino-ext-add-third-party-library.html
What’s the problem?
I used mac(OS Big Sur), and mblock 5.3.0.
Extensiones Arduino con más de una librería
Hi sthgood, can you copy the whole error message to us? It would be helpful to locate the problem. For now we can only see part of it in the last screenshot
I downloaded .mext and used it then, uploaded into arduino.
While uploading, I received this message.
start processing code…
processing code by middleware of pinMode
avr-toolchain/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"/Applications/Makeblock/mBlock.app/Contents/Resources/app/mlink-v1/external/arduino/avr-library/variants/standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/src/utility" -I"avr-library/libraries/Wire/src/" -I"avr-library/libraries/EEPROM/src/" -I"avr-library/libraries/SPI/src/" -I"avr-library/libraries/SoftwareSerial/src/" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/utility/" -I"arduino-libraries/arduino/Esplora/src/" -I"arduino-libraries/arduino/Firmata/" -I"arduino-libraries/arduino/Firmata/utility/" -I"arduino-libraries/arduino/Keyboard/src/" -I"arduino-libraries/arduino/Mouse/src/" -I"arduino-libraries/arduino/Robot_Control/src/" -I"arduino-libraries/arduino/Robot_Motor/src/" -I"arduino-libraries/arduino/RobotIRremote/src/" -I"arduino-libraries/arduino/Stepper/src/" “/Users/newmac/mblock-avr/temp/build/src/HX711.cpp” -o “/Users/newmac/mblock-avr/temp/build/src/HX711.o”
Command failed: avr-toolchain/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"/Applications/Makeblock/mBlock.app/Contents/Resources/app/mlink-v1/external/arduino/avr-library/variants/standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/src/utility" -I"avr-library/libraries/Wire/src/" -I"avr-library/libraries/EEPROM/src/" -I"avr-library/libraries/SPI/src/" -I"avr-library/libraries/SoftwareSerial/src/" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/utility/" -I"arduino-libraries/arduino/Esplora/src/" -I"arduino-libraries/arduino/Firmata/" -I"arduino-libraries/arduino/Firmata/utility/" -I"arduino-libraries/arduino/Keyboard/src/" -I"arduino-libraries/arduino/Mouse/src/" -I"arduino-libraries/arduino/Robot_Control/src/" -I"arduino-libraries/arduino/Robot_Motor/src/" -I"arduino-libraries/arduino/RobotIRremote/src/" -I"arduino-libraries/arduino/Stepper/src/" “/Users/newmac/mblock-avr/temp/build/src/HX711.cpp” -o “/Users/newmac/mblock-avr/temp/build/src/HX711.o” /Users/newmac/mblock-avr/temp/build/src/HX711.cpp:11:10: fatal error: HX711.h: No such file or directory #include <HX711.h> ^~~~~~~~~ compilation terminated.
Failed to compile file src/HX711.cpp
arduino build failed.
Cannot add my extension TM1637
Hi sthgood, please try to change #include <HX711.h> to #include “HX711.h” and see what happens
Thank you for your help.
I did it. You can see upper picture, written “src/HX711.h”.
I think, you mean, do I have to change HX711.cpp?
I made it. Thank you very very very much.
I changed <hx711.h> to “hx711.h” in hx711.cpp.
Then, everything is OK!
Yes, glad to know that and you are welcome!
