The usb port of mblock is damaged
Hello everyone. I have a little problem with mbot port : two days ago mbot just fell off the table and when i checked on him the usb port was damaged. After the accident when i try to upload a code or update the firmware it failed and the red led can’t stop flashing when i connect to the pc so can someone help me ?
Depends on your tools and skill. You could try to replace the usb port by (de)soldering. Or take out the bluetooth module and use those female pin connectors to hook up your board to for instance a common arduino flasher. The pin connectors consist of Tx, Rx, 5V, Gnd, Rst, Nc, DTR
I used these connectors to hook up an esp8266 to control my mBot over WiFi. But basically you can attach anything that uses (some of) the above mentioned connectors.
To illustrate this is my project I mentioned.
