Ma ei sa vajutada “UUENDA PÜSIVARA” kui kasutan
2.4GHz jadaliidest pildi link on all
https://drive.google.com/file/d/1Vl8Ig67l4OxAfn5i9JgSPZaFQX3IQ6uI/view?usp=sharing
Aitäh, abi eest!!
Aitäh, abi eest!!
I’m finding that I need to use the following sequence to send commands over WiFi/Bluetooth:
For robots with the WiFi module:
For robots with the Bluetooth module:
Be aware that to disconnect from the USB cable, WiFi module, or Bluetooth module you will need to go to that item in the Connect menu and click it to unselect the connection.
The reason for the Upgrade Firmware/Reset Default Program sequence is that each version of mBlock is slightly different and therefore it is important to use the firmware associated with the version of mBlock that you are running. The “firmware” interprets the commands sent to the robot and executes them.
Hope this helps!
