Hi guys,
I just try to push a simple sketch to a nano Arduino from mBlock 3 with a Linux Ubuntu host.
This is the error I get:
Dez 01 23:22:02 myhost ideserverplus[13012]: Into usbList ==========================>
Dez 01 23:22:02 myhost ideserverplus[13012]: Into bluetoothClose ==========================>
Dez 01 23:22:02 myhost ideserverplus[13012]: 蓝牙连接已关闭
Dez 01 23:22:05 myhost ideserverplus[13012]: Into usbConnect ==========================> { port: ‘/dev/ttyUSB0’ }
Dez 01 23:22:15 myhost ideserverplus[13012]: Into usbSend ==========================> { data: [ 255, 85, 2, 0, 4 ], port: ‘/dev/ttyUSB0’ }
Dez 01 23:22:15 myhost ideserverplus[13012]: serial path /dev/ttyUSB0
Dez 01 23:22:16 myhost ideserverplus[13012]: open serial port ok
Dez 01 23:22:16 myhost ideserverplus[13012]: begin sync
Dez 01 23:22:16 myhost ideserverplus[13012]: stk500v2Instance sync
Dez 01 23:22:17 myhost ideserverplus[13012]: sync err Error: stk500 timeout. 200ms
Dez 01 23:22:18 myhost ideserverplus[13012]: sync done
Dez 01 23:22:19 myhost ideserverplus[13012]: Into usbList ==========================>
Dez 01 23:22:23 myhost ideserverplus[13012]: 7777777
Dez 01 23:22:23 myhost ideserverplus[13012]: { Error: stk500 timeout. 5000ms
Dez 01 23:22:23 myhost ideserverplus[13012]: at Timeout. (/opt/makeblock/ideserverplus/node_modules/stk500-v2/lib/parser-v2.js:112:21)
Dez 01 23:22:23 myhost ideserverplus[13012]: at ontimeout (timers.js:380:14)
Dez 01 23:22:23 myhost ideserverplus[13012]: at tryOnTimeout (timers.js:244:5)
Dez 01 23:22:23 myhost ideserverplus[13012]: at Timer.listOnTimeout (timers.js:214:5)
Dez 01 23:22:23 myhost ideserverplus[13012]: cause:
Dez 01 23:22:23 myhost ideserverplus[13012]: at Timer.listOnTimeout (timers.js:214:5) code: ‘E_TIMEOUT’ },
Dez 01 23:22:23 myhost ideserverplus[13012]: isOperational: true,
Dez 01 23:22:23 myhost ideserverplus[13012]: code: ‘E_TIMEOUT’ }
Dez 01 23:22:23 myhost ideserverplus[13012]: 88888
Dez 01 23:22:23 myhost ideserverplus[13012]: fail-----
Dez 01 23:22:23 myhost ideserverplus[13012]: Into bluetoothClose ==========================>
Dez 01 23:22:25 myhost ideserverplus[13012]: serial opening…
Dez 01 23:22:25 myhost ideserverplus[13012]: Into usbList ==========================>
Dez 01 23:22:28 myhost ideserverplus[13012]: Into usbList ==========================>
Dez 01 23:22:53 myhost arduino.desktop[30942]: Binary sketch size: 3,336 bytes (of a 30,720 byte maximum)
Dez 01 23:22:56 myhost arduino.desktop[30942]: Binary sketch size: 3,336 bytes (of a 30,720 byte maximum)
Dez 01 23:23:17 myhost ideserverplus[13012]: soket连接断开时,关闭后端所有的端口连接
Dez 01 23:23:17 myhost ideserverplus[13012]: 串口连接已关闭
Dez 01 23:23:17 myhost ideserverplus[13012]: 蓝牙连接已关闭
Dez 01 23:23:17 myhost ideserverplus[13012]: 2.4G连接已关闭
Dez 01 23:23:17 myhost ideserverplus[13012]: serial child disconnect.
Using the normal IDE Arduino everything works fine and I can upload the sketch correctly.
Can anybody help?
Many thanks
Alex
