Hi, some questions
the motors on slots 1 and 2, do they only work with external power supply?
Is a USB Powerbank with 5V sufficient or are 9V (Block Size or 6 x AA Size) necessary?
Is it possible to connect the external power supply and the USB cable for PC simultaneously?
Have the two power buttons 1) in the middle of the LEDs and 2) next to the power jack the same function or are they different?
The power button in the middle of the LEDs is labeled with “on/off”. But I can only turn it on. “off” does not work. Repeated pressing of this button is without any effect. How can I stop the robot without removing the external power supply?
Is there a list which commands from the Auriga list (Makeblock extensions) only work in Auriga mode (Upload) and which commands can also be used in Scratch mode (green flag)?
Many thanks, Gerhard
