Starter Kit bluetooth module
Just built the starter kit with my son. Ir control was fine but the dual mode bluetooth module is not. Ported into port 5 for bluetooth. My samsung android makeblock app can find the device but unable to connect. Bluelight on modules remains blinking.
Kindly assist.
Hi Colnie,
What is the Android system version on your samsung mobile device?
The Makeblock App works on Android 4.1 and above.
Besides, are you able to pair the makeblock bluetooth to your sumsung device under the mobile’s Bluetooth settings page.
If it can be paired successfully, then you can open the makeblock app and connect the Bluetooth from makeblock have a try.
If the makeblock Bluetooth can be paired under the mobile’s Bluetooth settings page but cannot be connected on the App, please kindly change the battery for the robot have a try either. According to our test and research, it is suggested to use rechargeable Li-ion battery or rechargeable nickel-metal hydride, nickel-cadmium which can be bought from amazon or local shop. Or Alkaline battery with good quality like Energizer, DURACELL.
