Helo, I have made a software using arduino for my mBot that follows a white line. I want to start it using the board button, but I don’t know how to write it in arduino, so I need your help. Thank you.
Start line follower using board button (I NEED HELP)
I think that I need some libraries to put that instruction into Arduino, I have already instaled MeMCore.h but it doesn’t work. Thank you anyways.
Here is an instruction on the learn website to guide adding Makeblock library to Arduino software.
I have already done it guys. The board button was set as A7 digital pin, so I made a void to initialize It using “if”, “else” and digitalRead.
I have done the same thing using mblock (mine goes on black line) and i have the following instructions:
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <MeMCore.h>
MeDCMotor motor_9(9);
MeDCMotor motor_10(10);
void move(int direction, int speed)
int leftSpeed = 0;
int rightSpeed = 0;
if(direction == 1){
leftSpeed = speed;
rightSpeed = speed;
}else if(direction == 2){
leftSpeed = -speed;
rightSpeed = -speed;
}else if(direction == 3){
leftSpeed = -speed;
rightSpeed = speed;
}else if(direction == 4){
leftSpeed = speed;
motor_9.run((9)==M1?-(leftSpeed):(leftSpeed));
motor_10.run((10)==M1?-(rightSpeed):(rightSpeed));
double angle_rad = PI/180.0;
double angle_deg = 180.0/PI;
MeLineFollower linefollower_3(3);
void setup(){
pinMode(A7,INPUT);
while(!((0^(analogRead(A7)>10?0:1))))
_loop();
if(((linefollower_3.readSensors())==(0))){
move(1,100);
}else{
if(((linefollower_3.readSensors())==(1))){
move(3,100);
}else{
if(((linefollower_3.readSensors())==(2))){
move(4,100);
}else{
move(2,100);
void loop(){
_loop();
void _delay(float seconds){
void _loop(){
i don’ t know if i helped, i am trying to make it start when button pressed and also stop when button pressed for the second time…no luck yet!
To make the button start and stop the mBot, you’ll need to keep a variable, called a state variable that contains the current state of the mBot (moving / not moving) and you will need to check that every time you go through your loop. The example below plays a tone but uses the onboard button to control the state of the program. I left in the debugging Serial.println statement so that you can see the current value of the state variable in the serial monitor.
#include <Wire.h>
#define NOT_RUNNING 0
#define RUNNING 1
int state;
MeBuzzer buzzer;
void setup(){
state = NOT_RUNNING;
Serial.begin(9600);
pinMode(A7,INPUT);
// wait until onboard button pressed
while (state == NOT_RUNNING) {
checkButtonPress();
while (state == RUNNING) {
Serial.println("State: " + String(state));
playTone();
checkButtonPress();
void loop() {
void playTone() {
if (state == RUNNING) {
// play the tone
buzzer.tone(392, 500);
delay(20);
} else {
// turn off the tone
buzzer.tone(0, 500);
void checkButtonPress() {
if (analogRead(A7) == 0) {
// onboard button has been pressed, toggle state
state = !state;
