My daughter just received a Codey Rocky. We are experimenting the features but the sound sensor doesn’t seem to respond when coding basic things. Is there a way to test the sound sensor?
Thank you from a newbie
Will you show me how did you find the sound sensor is not working? Just show me you coding?
You can test the sound sensor with below program:
Then let it “listen” sounds, will it show you the changing value?
Could you tell me how to quote some coding in a message?
Basically “when loudness more than …show image …” will work with loudness set to 5 but not with loudness set to 4, which doesn’t make a lot of sense
The program you propose, sends me a value of 2,8 in a silent room, but will blink, and would react to my voice most of the time but not always. Does that mean the sound sensor is deficient?
I am afraid that is the voice from you is not always changing a lot, which is a little bit different from what we heard. Please try to change the voice source, like I tested with clapping my hands, every time it feels it.
