Some Tips for Starter Kit and Scratch App
When we started, we had a few problems. So I wrote a few notes to help people in case they are having similar problem. I hope it helps.
Notes for using the Scratchbot Application:
  1. Connect the Robot to the USB Port, the Robot should light up. A single beep occurs.
  2. In the “Connect” menu, select the COM port, another beep.
    Also - the MakeBlock Starter Robot is type “Arduino Leonardo”
  3. In order for the program to run, the Robot must also be turned on.
    The motors are powered by the batteries, not the USB.
  4. The motors are reversed from each other. So to go in one direction one must be set to a positive number and the other to a negative number.
    For example:
    set motor M1 speed 300
    set motor M2 speed -300 This will make the robot go forward.
We put a box in between the tires and prop the robot up. This allows the wheels to turn but the Robot to stay still. Good for working on a program.
More tips:
  1. The ultrasound sensor is in Port 3, just a reminder.
  2. When you move the motors - you need to set it more than 100, otherwise there is not enough power to move the Robot. It will buzz, and you’ll wonder what’s wrong.
  3. The distance your robot goes depends on a combination of the “speed” and the time using the “wait” command. So if you set the speed for 100, and the wait for 5 seconds - this will go half the distance of speed 100 for 10 seconds. This isn’t as obvious as it sounds. Mixing up the speed and wait will yield varying results.
