[SOLVED] PC Bluetooth connection trouble with mBot Ranger
"Hello everyone,
I recently bought a second-hand mBot Ranger. It seems to work well; I can control it from my smartphone and program it on my PC via the MakeBlock application. The only downside is that I can’t connect it via Bluetooth from my PC, which is inconvenient when testing things live.
I’m using a Windows 11 PC. I should mention that the Bluetooth pairing between the PC and the mBot seems fine (it appears my PC detects it).
I tried to solve the issue with my son’s PC… same result.
Does anyone have any ideas to help me out?
Thanks in advance,
Best regards!"
Hi Franck @FLem
You really do have to buy Makeblock’s own Bluetooth Dongle (which somewhat confusingly is actually a Serial device not a Bluetooth device) to make your Ranger or any other Makeblock bot work with a Bluetooth connection:
HI CommandeR!
Thank you very much for your feedback and your efficiency!!!
I will try this method and keep you informed.
Best regards
Hi Franck @FLem
This dongle does work (& is therefore worth the money) whereas other Bluetooth connections don’t. Good luck!
Hi
Great!
It works.
Thanks a lot!
Best regards
Is it safe to mark this as solved? :slight_smile:
