the servo does not work as intended
can you help?
here are some screenshots
any idea why it does not work?
can you help?
nvm i found the problem, you guys can mark this as solved
here was the problem,
i was in a forever loop,
witch means it was updating idk like 1000 times per second, so by the time we pressed and let go of the button the servo stuff was called like 100 times,
all i did was add some script to only update it once every 20 updates (they are better ways)
time++
if (time % 20 == 0) {
// call all the functions
