[SOLVED] Codey Rocky firmware updates aren't working
Hello everyone!
Im a begginer and im using codey to learn the first steps. I have a lot of problems connecting the codey to my pc, and mbock says me that my codey need a firmware update.
I try in diferent times pdate my robot, but it’s not possible.
Now, my codey only has a red light flashing in the center screen and 3 Exclamation points.
I’m very confused and im thinking that my codey has irreversible damage.
Can you help me, please?
Thanks for your time commnity!
Dani
@danineco I’ve never seen a Codey do that before! Have you tried plugging in your Codey to charge it? I’ve seen similar behavior with a low battery. Connect your Codey to a charger, make sure the Codey is off, and let it charge until the charging indicator on Codey is green.
If you still have issues, try updating the firmware with both the PC and online (https://ide.mblock.cc) versions of mBlock, or reach out to makeblock support via email here:
support@makeblock.com
Good luck!
Hello thanks for your answer. My codey is full of charge, and green light on the top. I tryed to update firmware in online version mboot and standalone version, but have no good results.
i found a solution!
solved!
https://support.makeblock.com/hc/en-us/articles/4402733426327-Update-the-Firmware-of-Codey-Rocky
@danineco Awesome! Glad that worked. :slight_smile: Let me know if you need help with anything else.
