[SOLVED] Can't connect my mbot Ranger to my phone
Hey,
I got a mbot ranger for Christmas and I have build it.
It work perfectly fine on my pc with USB but when I test with Bluetooth, it doesn’t work
I have also try block blocky and found but says " Incompatible peripherals or firmware not detected "
I have updated to the latest firmware but nothing
Thank,
Kylian
Hello there! Have you tried updating it through your pc?
Note: If you have code uploaded to the robot, it will not connect to the mobile app. Update the robot with your PC to remove code.
Hey, my ranger have the latest firmware but I have already put some code in here, I will reset and tell you more
Kylian
It’s worked, thank a lot
You’re welcome!
