Greetings @Pioneer,
I’m having an “interesting” issue with mBlock. When I go to save my project, prior to shutting down mBlock, the program pops up my browser with the feedback form. Is that intentional?
Regards,
Charles
Greetings @Pioneer,
Regards,
Charles
@Charles, its not intentional, which version of mBlock are you using and the model of your computer? is the problem popup suddenly, or always perform like so? You can try to uninstall the software and install again, then again to have a try.
iMac / OS X 10.11.3
mBlock 3.2.2
I’ve uninstalled and reinstalled and it seems to be occurring intermittently now. Not sure what’s going on. Also had some weirdness earlier where an mBot program would run from the mBlock environment only when the USB cable was attached and not otherwise. Much weirdness that I haven’t seen happening before. :-/
Same problem with me, if this happen nothing will saved anymore and data might lost. Config is similar to @chuckmcknight:
MBP / OS X 10.11.3
Cheers
Thorsten
