Robotic arm add on - general question
Hi, I Inderstand from the product information that the Gropper will stop moving when fully opened or closed. What will happen if an object is picked up? Will the motor bei damaged If not stopped manually?
Thks, S.
Hi there:
From my experience,in example program the motors were set to a perfect angle to pick up the items and there is limitation of our block,but when you use a block that create by inappropriate angle,the anwser is yes,it will cause a short circuit due to prolonged stuck.
